Local NAT for some Destinations
Hi all.
I have this problem  on my productive network.
I routed all my branches on my Central branch, but I need use the Local internet service for some hosts (like Akamai) so I have replied the base configuration on GNS3.
R1 Config.
interface FastEthernet0/0
ip address 10.10.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1 (Connecter to NAT1 emulating nat)
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
ip forward-protocol nd
ip route 10.100.50.0 255.255.255.0 10.10.0.2 name LAN-prueba
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet0/1 overload
access-list 10 permit 10.100.50.0 0.0.0.255
no cdp log mismatch duplex
R2 Config
for practical test I trie to reach the host 8.8.4.4. from de local  Internet service
ip address 10.10.0.2 255.255.255.0
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip address 10.100.50.1 255.255.255.0
ip nat inside
ip default-gateway 10.10.0.1
ip route 0.0.0.0 0.0.0.0 10.10.0.1 name Default-salida
no ip http server
ip nat inside source route-map NAT_SPLIT interface FastEthernet0/1 overload reversible
access-list 100 remark macheo para natear por otro lado.
access-list 100 permit ip 10.100.50.0 0.0.0.255 host 8.8.4.4
route-map NAT_SPLIT permit 10
match ip address 100
match interface FastEthernet0/1
route-map NO_NAT-SLIPT permit 10
match ip address 1
match interface fastethernet0/=
regrests!
18 Replies 18
ip address dhcp
ip nat outside
duplex auto
speed auto
ip policy route-map MHM
match ip address 1 <<- what is this ACL
route-map MHM permit 10
set interface  FastEthernet0/1
Sorry my Bad
match ip address 1 <<- what is this ACL  same acl --> 100
route-map NO_NAT-SLIPT permit 10 <<<- NO NEED THIS ROUTE-MAP
final confing
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip route 0.0.0.0 0.0.0.0 10.10.0.1 name Default-salida <<- this default route for any traffic not direct toward host 8.8.4.4
no ip http server
route-map NAT_SPLIT permit 10 <<- this for NATing traffic
route-map MHM permit 10 <<- this for forward traffic
Hello
You don’t mention if you wish for resiliency incase either ISP connection fails.
So just based on your OP try to allow:
  • Router 1 to perform NAT for both subnets 10.100.50.0/24 & 10.10.0.0/24
  • Router 2 apply a single static nat statement with policy route to nat egress to its own wan interface.
Router 1
access-list 10 permit 10.10.0.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 dhcp
Router 2
route-map PBR
interface Vlan1
ip policy route-map PBR
no ip route 0.0.0.0 0.0.0.0 10.10.0.1 name Default-salida
no ip nat inside source route-map NAT_SPLIT interface FastEthernet0/1 overload reversible
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 10.10.0.1 name Default-salida
ip nat inside source list 100 interface FastEthernet0/1
Kind Regards
Paul
Hi paul. I matched all config but i dont have internet access when pinig 8.8.4.4 i see the match of the access list but is not nating.
interface Vlan1
ip nat inside
no ip http server
ip nat inside source list 100 interface FastEthernet0/1 overload
that not complete config
notice there are two PBR
HI MHM with this config y nated through the 10.10.0.1. My idea is when i have go to 8.8.8.8 go to 10.10.0.1. when i need go to 8.8.4.4 i need use the local Nat of the router.  i like a doble NAT 8.8.8.8 for one way and 8.8.4.4 to the other path.
i use both route maps.
Share last config all i will check and make note
yes ofcurse
full config R2.
R2#sh run
Building configuration...
Current configuration : 2279 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 20
no ip icmp rate-limit unreachable
ip cef
no ip dhcp use vrf connected
ip dhcp pool DHCP_10.100.50.x
network 10.100.50.0 255.255.255.0
default-router 10.100.50.1
dns-server 10.100.50.1
no ip domain lookup
ip name-server 10.10.0.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vlan ifdescr detail
ip tcp synwait-time 5
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
ip nat inside
no ip http server
match interface FastEthernet0/0
control-plane
gateway
timer receive-rtp 1200
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Only this no need
Also the f0/1 get ip from dhcp ?
Are you sure it get ip?
Do
Show ip interface breif
To check if f0/1 get ip or not.
Hi MHM
yes it having a DHCP from the Cloud.
debug ip packet give me hint what issue here,
the encapsulation issue
TRY
NO set interface FastEthernet0/1
set ip next-hop recursive <CLOUD IP
Hi MHM. this config is better i geve you the traceroute and debug.
PC1> trace 8.8.8.8
trace to 8.8.8.8, 8 hops max, press Ctrl+C to stop
1 10.100.50.1 19.771 ms 9.559 ms 10.008 ms
2 10.10.0.1 19.447 ms 19.356 ms 19.327 ms
3 192.168.122.1 29.316 ms 29.684 ms 30.114 ms
4 10.10.0.1 29.495 ms 29.958 ms 29.243 ms
5 * * *
^C 6
PC1> trace 8.8.4.4 <--- is going to the cloud without goint to 10.10.10.1
trace to 8.8.4.4, 8 hops max, press Ctrl+C to stop
1 10.100.50.1 10.386 ms 9.829 ms 9.276 ms
2 192.168.122.1 19.838 ms 19.790 ms 19.799 ms
3 10.10.0.1 19.771 ms 19.791 ms 19.848 ms
4 * * *
5 * * *
6 * * *
^C 7 * *
PC1> trace 8.8.8.8
5 * * *
^C 6
PC1> trace 8.8.4.4
4 * * *
5 * * *
6 * * *
Debug ip Packet
*Mar 1 00:15:24.275: IP: tableid=0, s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:24.275: IP: s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), len 56, sending
*Mar 1 00:15:24.279: ICMP type=11, code=0
*Mar 1 00:15:24.295: IP: tableid=0, s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:24.295: IP: s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), len 56, sending
*Mar 1 00:15:24.295: ICMP type=11, code=0
*Mar 1 00:15:24.303: IP: tableid=0, s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:24.303: IP: s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), len 56, sending
R2#
*Mar 1 00:15:24.303: ICMP type=11, code=0
R2#
*Mar 1 00:15:29.675: IP: tableid=0, s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:29.675: IP: s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), len 56, sending
*Mar 1 00:15:29.675: ICMP type=11, code=0
*Mar 1 00:15:29.687: IP: tableid=0, s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:29.687: IP: s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), len 56, sending
*Mar 1 00:15:29.687: ICMP type=11, code=0
*Mar 1 00:15:29.699: IP: tableid=0, s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:29.699: IP: s=10.100.50.1 (local), d=10.100.50.2 (Vlan1), len 56, sending
*Mar 1 00:15:29.699: ICMP type=11, code=0
*Mar 1 00:15:29.719: IP: tableid=0, s=192.168.122.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:29.719: IP: s=192.168.122.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), g=10.100.50.2, len 120, forward
*Mar 1 00:15:29.719: ICMP type=11, code=0
*Mar 1 00:15:29.735: IP: tableid=0, s=192.168.122.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:29.735: IP: s=192.168.122.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), g=10.100.50.2, len 120, forward
*Mar 1 00:15:29.739: ICMP type=11, code=0
*Mar 1 00:15:29.755: IP: tableid=0, s=192.168.122.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:29.759: IP: s=192.168.122.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), g=10.100.50.2, len 120, forward
*Mar 1 00:15:29.759: ICMP type=11, code=0
*Mar 1 00:15:29.779: IP: tableid=0, s=10.10.0.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:29.779: IP: s=10.10.0.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), g=10.100.50.2, len 56, forward
*Mar 1 00:15:29.779: ICMP type=11, code=0
*Mar 1 00:15:29.799: IP: tableid=0, s=10.10.0.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:29.799: IP: s=10.10.0.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), g=10.100.50.2, len 56, forward
*Mar 1 00:15:29.799: ICMP type=11, code=0
*Mar 1 00:15:29.819: IP: tableid=0, s=10.10.0.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), routed via FIB
*Mar 1 00:15:29.819: IP: s=10.10.0.1 (FastEthernet0/1), d=10.100.50.2 (Vlan1), g=10.100.50.2, len 56, forward
*Mar 1 00:15:29.819: ICMP type=11, code=0
R2#
Yes I see there is no more encapsulation error anymore, and the debug is OK BUT
still 10.10.0.1 appear, are both cloud interconnect ?
