Local NAT for some Destinations
Hi all.
I have this problem  on my productive network.
I routed all my branches on my Central branch, but I need use the Local internet service for some hosts (like Akamai) so I have replied the base configuration on GNS3.
R1 Config.
interface FastEthernet0/0
ip address 10.10.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1 (Connecter to NAT1 emulating nat)
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
ip forward-protocol nd
ip route 10.100.50.0 255.255.255.0 10.10.0.2 name LAN-prueba
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet0/1 overload
access-list 10 permit 10.100.50.0 0.0.0.255
no cdp log mismatch duplex
R2 Config
for practical test I trie to reach the host 8.8.4.4. from de local  Internet service
ip address 10.10.0.2 255.255.255.0
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip address 10.100.50.1 255.255.255.0
ip nat inside
ip default-gateway 10.10.0.1
ip route 0.0.0.0 0.0.0.0 10.10.0.1 name Default-salida
no ip http server
ip nat inside source route-map NAT_SPLIT interface FastEthernet0/1 overload reversible
access-list 100 remark macheo para natear por otro lado.
access-list 100 permit ip 10.100.50.0 0.0.0.255 host 8.8.4.4
route-map NAT_SPLIT permit 10
match ip address 100
match interface FastEthernet0/1
route-map NO_NAT-SLIPT permit 10
match ip address 1
match interface fastethernet0/=
regrests!
18 Replies 18
I will correct your config
Hello
I see an error in the config i sent you-Please change it the the following and test again?
route-map PBR deny 5
route-map PBR permit 10
no match ip address 100
interface Vlan1
ip policy route-map PBR
Kind Regards
Paul
Hi Paul, now I  a can reach 8.8.4.4 BUT for the same path (throght 10.10.0.1) and cant reach 8.8.8.8.
Hello
Thats is because you have not removed the nat statements i suggested you to remove!
no ip route 0.0.0.0 0.0.0.0 10.10.0.1 name Default-salida
no ip nat inside source route-map NAT_SPLIT interface FastEthernet0/1 overload reversible
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 10.10.0.1 name Default-salida
ip nat inside source list 100 interface FastEthernet0/1
Kind Regards
Paul
