local port forwarding from nat
ronpitts1
Hi All,
I'm wondering how I go about solving port forwarding from the LAN when using a public ip address.
I've setup a Cisco 2911 to NAT certain ports to various internal ip address via this command
     ip nat inside source static tcp 192.168.1.200 80 some.internet.ip.address 80 extendable
This works fine from outside (public internet) and the port is forwarded correctly.
However any internal IP's are sent to the Cisco router instead of the 192.168.1.200 when they use the "some.internet.ip.address".
I could in theory update the DNS to use the internal IP but I'm wondering if there is another way around this?   Maybe the reverse of the command?
7 Replies 7
cadet alain
configuring NAT NVI should let you do NAT hairpinning like you want to.
int x/x
no ip nat in
ip nat enable
no ip redirect
int y/y
no ip nat out
ip nat enable
no ip redirect
no ip nat inside source static tcp 192.168.1.200 80 some.internet.ip.address 80 extendable
ip nat  source static tcp 192.168.1.200 80 some.internet.ip.address 80 extendable
Alain
the best way to do this is update your DNS, however either you can configure NVI nat or can configure NAT hairpinning to make it work with legacy nat.
sample config on NATROUTER:
interface FastEthernet0/1
description "internal interface"
ip nat inside
interface FastEthernet0/0
description "outside interface"
ip address 202.2.2.1 255.255.255.252
ip nat outside
ip nat pool public 202.2.2.129 202.2.2.254 prefix-length 25
ip nat inside source list 101 pool public overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside
ip nat outside
interface Loopback0
ip address 10.1.1.1 255.255.255.0
ip nat outside
ip nat pool INTERNAL 10.1.1.2 10.1.1.254 prefix-length 24
ip nat inside source static 192.168.1.200 202.2.2.222
ip nat outside source list 102 pool INTERNAL
access-list 101 deny  ip 192.168.1.0 0.0.0.255 host 202.2.2.222
access-list 102 permit ip 192.168.1.0 0.0.0.255 host 202.2.2.222
ip route 202.2.2.222 255.255.255.255 10.1.1.2
Vinod
Thanks Cadet.
I'll give it a retry.
I;m assuming the key commands are :
no ip redirect
Hi Ron,
The key here is no more nat inside/nat outside just ip nat enable on the interfaces and no more inside keyword in the static nat.I've never tried without no ip redirect but I think it won't work without if I reckon correctly.
Alain
saavedra29_orig
cadet alain I didn't know that the 'inside' keyword in the static nat and nat inside/nat outside are deprecated!
I ended here after searching a solution about accessing my local server. I wonder how can someone get a briefing when Cisco makes such major changes. It's not good to spend half an hour for something so simple.
Thanks.
Aristeidis,
The inside keyword is not deprecated. The way of configuring NAT without inside/outside designations is a different approach to NAT and stands in parallel to the existing NAT functionality.
Best regards,
Peter
saavedra29_orig
Peter sorry, i thought it was deprecated because it didn't work just in my case.
