How can I use my both ISP's simultaniusly with BGP network
damcotech
I have published one network (Say 103.252.245.0/24) with my BGP settings. I use two providers using BGP to provide connections. I have made them primary and secondary. Now I want to use this like my half range of network IP's would be publish by ISP-1(Primary) and other half would be publish by ISP-1(Secondary).
Or
Mukesh
Collin Clark
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml
There's also a really good presentation on eBGP design on CiscoLive.com
joshuacmoore
Since you only own a class C network, traffic management is going to be best path to both providers. You will have to advertise the /24 to both peers and see how inbound path selection is working. You can try pretending an AS path to the provider that has too much throughout but in my experience this just causes all traffic to move to the second provider. This may be different for you though so I encourage you to experiment.
Annu,
Let me see if I understand this correctly. As of right now, you are advertising for example (100.100.100.0/24) to ISP-A and ISP-B? But you would like to have a /25 range of the /24 advertised to ISP-A and the other advertised to ISP-B?
Are both of these ISPs connected to one router, or two routers with a routing protocol between them? Also, are you doing Full Internet tables or default routes?
