local subnet not able to see remote networks passed 3850
tcrane8080
i just installed a 3850 and my local site is not able to see any networks passed the 3850.
i believe EIGRP STUB CONNECTED SUMMARY command is causing this.
any thoughts?
Thanks!
10 Replies 10
Jon Marshall
Bit difficult to say without more details.
Jon
Jon, i'll attach a "sh run" for ya.
the putty output is from the 3850
Do the upstream devices have routes for those local subnets ie. I notice you have a default route on the 3850 pointing to an upstream device.
Jon
let me check the 3850's default route.
yeah, with EIGRP running the local LAN should know about the 3850's network and the networks passed it.
i have another site with basically the same topo that i haven't touched and it's running fine.
so, i've screwed something up when i added the 3850
I notice you also have another default route pointing to 10.30.31.254.
Whatever that device is you are not running EIGRP with it are you ?
Jon
i have a 1841 connected to the SW for the backup link.  Since the SW doesn't have a serial port i have the RTR connecting to a cradlepoint.  which, when the main connection, 10.30.13.9 goes down the traffic goes out the RTR and thru the cradlepoint
Can you post a "sh ip eigrp neighbor detail" from both the 3850 and the upstream device ie. the main default route device.
Just to clarify you have checked the upstream device and it has routes back to the 3850 local subnets ?
Jon
HaysRTR#sh ip eigrp nei
EIGRP-IPv4 Neighbors for AS(100)
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
2   10.30.13.9              Gi1/0/24                 12 03:20:52  808  4848  0  71335
1   10.30.12.11             Vl11                     14 03:20:56    8   100  0  20145
0   10.30.31.253            Vl1                      10 03:20:56    1   100  0  22959
below is the L3 switch that connects to the 3850:
KWCHSW15#sh ip route 10.30.31.0
Routing entry for 10.30.24.0/21
  Known via "eigrp 100", distance 90, metric 3072, type internal
  Redistributing via eigrp 100
  Last update from 10.30.13.10 on Vlan202, 03:22:17 ago
  Routing Descriptor Blocks:
  * 10.30.13.10, from 10.30.13.10, 03:22:17 ago, via Vlan202
      Route metric is 3072, traffic share count is 1
      Total delay is 20 microseconds, minimum bandwidth is 1000000 Kbit
      Reliability 255/255, minimum MTU 1500 bytes
      Loading 1/255, Hops 1
the int 24 on the 3850:
interface GigabitEthernet1/0/24
 description NetVX Connection to KWCH
 no switchport
 ip address 10.30.13.10 255.255.255.252
and, please ask away!
What happens if you just configure the 3850 as normal EIGRP ?
Jon
Jon, sorry for the delay!!
what i found was the new 3850's come from the factory with a "universal" IOS and
what determines which services are these lines when you do sh ver:
License Level: Ipservices
License Type: Permanent
Next reload license Level: Ipservices
once i ran license right-to-use activate ipservices all acceptEULA
IPservices was enabled.
Thanks for your asistance!!
