Locking Down NTP
ryancisco01
Level 4
Level 4
We got an email stating one of our Cisco routers was an open NTP server.
The router only needs to be able to sync its time with a internet based time server. It does not need to serve its time to anyone else. So I did the following:
access-list 30 permit 203.99.129.34 0.0.0.0
access-list 30 deny any
access-list 40 deny any
ntp access-group peer 30
ntp access-group serve-only 40
ntp access-group query-only 40
ntp server 203.99.129.34
Now I can see heaps of hits against the deny entry. However when I use an online tool like:
http://keetweej.vanheusden.com/query_ntp.php It can still see my NTP server details (exactly the same amoutn as if I remove the access-groups), which means it must be repsonding to the NTP query. I don't have an access-list on my outside interface so would prefer not to do it that way. But have I done enough to block the NTP securty risk?
5 Replies 5
ryancisco01
Level 4
Level 4
Just had them retest, they are saying the NTP server is still open.
abpsoft
Level 2
Level 2
is this IOS XE running on the router in question? I've got a similar problem with 4500Xs running IOS XE and configured with just an access-group peer statement actually responding to ntpq -p, while it isn't responding to regular time queries (ntpdate -d). That's apparently a bug, given the ACL in question counts these queries on the deny all ACE, but answers come back anyway. My thread didn't get replies so far, just one me too vote.
HTH,
Andre.
mvsheik123
Level 11
Level 11
The below config helped me resolving similar issue raised by our external pen testing firm....
access-list 30 remark PUBLIC NTP SERVERS
access-list 30 permit x.x.x.x
access-list 30 permit y.y.y.y
ntp max-associations 2
ntp server x.x.x.x
ntp server y.y.y.y
hth
MS
MS, My config was exact the same as yours except I had deny anys at th ebototm of my ACL's, rem oved those and still the same thing.
Can you try tetsing it yourself? if you go to this website
http://keetweej.vanheusden.com/query_ntp_do.php and put in your IP address, you should get no reply. However I am still seeing all my NTP information being able to be retrived even though that website is not in the permitted ACL.
Andre, this is not XE, its IOS 15.2 does seem like a bug.
I just tested this the other way:
Extended IP access list 100
    permit ip host 203.99.129.34 any
    deny udp any any eq ntp (45 matches)
    permit ip any any (2276 matches)
and put that on the outside interface. Now the NTP internet test cannot query the NTP. So i believe this is a bug with the NTP access-group command. it doesn't seem to have any effect.
Would be good for an official word on this, putting an ACL on the outside interface is not an ideal solution.
ryancisco01
Level 4
Level 4
Well here we go, this is the issue:
https://tools.cisco.com/bugsearch/bug/CSCuj66318
IOS bug!!
fixed in 15.4
