Log error : %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to process Signature in disk2:!P!N@pA55.
Muradazz
any one can help ne to know what is this error at the Log  and if it will impact the service
Mar  4 10:59:03.138: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to process Signature in disk2:!P!N@pA55.
Mar  4 12:09:38.470: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to process Signature in disk2:!P!N@pA55.
Mar  4 12:25:32.074: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to process Signature in disk2:!P!N@pA55.
Mar  4 12:35:53.192: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to process Signature in disk2:!P!N@pA55.
5 Replies 5
Muradazz
my router model  is 7200
System returned to ROM by reload at 12:20:10 GMT Tue Jun 11 2013
System restarted at 12:22:28 GMT Tue Jun 11 2013
System image file is "disk2:c7200p-advipservicesk9-mz.151-3.S5.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 37073107
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
254464K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
what is the output of:
dir disk2:
Is the command 'verify' available in your IOS ? If so, try:
7206VXR#verify disk2:
hi  thanks   for your reply
Directory of disk2:/
1 -rw- 28135296 Aug 4 2012 05:50:50 +00:00 c7200p-advipservicesk9-mz.bin
2 -rw- 23299780 Apr 12 2011 04:38:00 +00:00 c7200p-spservicesk9-mz.124-4.XD7.bin
3 -rw- 28120148 Jan 28 2012 17:14:58 +00:00 c7200p-advipservicesk9-mz.122-33.SRE4.bin
4 -rw- 32257096 Jun 11 2013 11:47:30 +00:00 c7200p-advipservicesk9-mz.151-3.S5.bin
260124672 bytes total (148303872 bytes free)
Hello
Do you have a Cisco cco account?
if so you can download this excellent tool and it will enable you to log onto the device  and then it will check any crash file in addition to the cli will report any anomalies of the software.
Cisco cli analyser
Kind Regards
Paul
hi thanks   for your support  but i did not get  useful  result
Error message (Seen 76 times, the most recent at Mar 10 19:33:25.914):
SIGNATURE-3-NOT_ABLE_TO_PROCESS : %ERROR: Not able to process Signature in [chars].
Explanation:
An unknown error occurred when the system attempted to process the signature in the specified image file. A valid signature ensures the integrity of the image.
Recommended Action:
Do not use this file. The file might be corrupted or modified. Attempt to copy the file again, or download the file again from the Cisco.com page before copying it. If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the information you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs.
