LOG ERROR
anajustiniano
Im checking the logs on the router and im getting this log:
" CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed "
Im wondering why Im getting this log and how can I fix it.
Any help wll be appreciated....
InayathUlla Sharieff
Ana,
What device , what IOS
show version would help.
This output shows an example of the 'Replay Check Failed' error:
"%CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed connection id=#."
This error is a result of reordering in transmission medium (especially if parallel paths exist), or unequal paths of packet processing inside Cisco IOS for large versus small packets plus under load. Change the transform-set to reflect this. The reply check is only seen when transform-set esp-md5-hmac is enabled. In order to surpress this error message, disable esp-md5-hmac and do encryption only. Refer to Cisco bug ID CSCdp19680 ( registered customers only) .
http://www.cisco.com...0800949c5.shtml
Below are some reference in regards to this error:
https://supportforums.cisco.com/document/9021/user-recieves-crypto-4-pktreplayerr-decrypt-replay-check-failed-error-message-multi
Inayath
*Plz dont forget to rate if this info is helpfull.
Ana,
Inayath
Thank you for the information, it was very usefull.
I was able to correct the error by  Expanding the Anti-Replay Window to the recomended size (1024).
