Log message is not logged in buffer
yunchouljung
Hello
my name is yun choulj jung in korea
Yesterday, i changed a logging buffer size in Catalyst 4510R-E and up and down the fastethernet interface.
but interface up/down status is not logged in buffer memory.
so, i rechanged a configuration originally and reboot the chassis.
but log was not saved in buffer.
i know the bug id CSCdu60369.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCdu60369
So, i "no logging syncrous" command enterd but result was same.
Environment
C4510R-E (cat4500-entservicesk9-mz.122-31.SGA11.bin)
H_NEW4510R_A#show logg
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 329 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 6 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 89 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level informational, 333 message lines logged
Log Buffer (4096 bytes):
i attached the configuration
tell me the workaround or advice.
thanks in advance.
by yunchouljung
Brandon Lynch
Hey Yun Choulj Jung,
Can you try configuring the following globally on the switch -
logging event link-status
If that doesn't take, try going into the interface configuration and configuring it.  Then, bounce the interface and let me know what you find.  Thanks.
Brandon
Brandon Lynch
Brandon
thank you, brandon
the problem is resolved because of you
again, thank you very much!
