Logging Message on Router
Reza_Mohd
I would appreciate if I can get any help regarding stopping the logging message. I did run the command no logging console but even I'm keep getting the same.
Thank you.
Regard
Reza
16 Replies 16
Router(config)#logging console 5
Router(config)#logging buffered 5
Since the log messages are level 6, the above commands should get rid of the messages you see....
Hello
First you need to establish what logging you have running
show logging
Then once you've establish that you can either decrease the logging level so the message you are receiving isnt included in that level or you can apply a log discriminator
conf t
logging discriminator STAN msg-body drops "title-of-MSG to drop"
logging monitor discriminator STAN <log level>
Kind Regards
Paul
