Logging suppress on ios-xr CRS queston!
fly
Level 2
Level 2
Hi,Experts,
     we found some logging message on CRS ios-xr
     umass-enum[95]:USB:cannot open /dev/usb00:No such file or directory
    we want to suppress this logging message , and found document:
    https://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r4-2/system_monitoring/configuration/guide/b_sysmon_cg42crs/b_sysmon_cg42crs_chapter_0100.html
   but this method just only can supress log format as below
node-id : timestamp : process-name [pid] : % message category -group -severity -message -code : message-text
This is a sample syslog message:
RP/0/RP0/CPU0:router:Nov 28 23:56:53.826 : config[65710]: %SYS-5-CONFIG_I : Configured from console by console
   how can suppress loggging message like below:
   no category  no group no code
   thank you
Jere
nishetti
Try this in a Maintenance Window
run ls /dev/usb00
process restart umass-enum location 0/RSP1/CPU0
process restart umass-enum location 0/RSP0/CPU0
run ls /dev/usb00
