login user get default privilege
kerek
Level 4
Level 4
I have played a bit with assigning different privilege level to a user, but seems not working because always get the default level assigned to the particular line.
Config:
username dummy privilege 7 password dummy
aaa authentication login enhanced local
line vty 1
login authentication enhanced
after login into the router through line 1 with the dummy user I get privilege level 1.
Line User Host(s) Idle Location
2 vty 0 idle 00:00:50
* 3 vty 1 dummy idle 00:00:00
router>s priv
Current privilege level is 1
Is it a bug or i have missed something?
Krisztian
Edison Ortiz
You are missing the authorization piece of the AAA.
aaa authorization exec enhanced local if-authenticated
Edison Ortiz
Yes it is working now, but I had to add the authorization exec enhanced under the particular line.
Krisztian
Hi ,
Since you are using named method list, that is why you had to add it in particular line.
~JG
Yes, if you would use method that is named "default", you wouldn't have to configure it under the line, only in global.
