looking for help on BGP advertisements and ip SLA
rreimer
i have a cisco 3825 running c3825-entservicesk9-mz.124-25g.bin.
it has 2 interfaces
a WAN that has BGP peering with 2 upstream neighbors
a local interface that is connected to a siwtch and then to a firewall (216.224.132.161/27 router, 216.224.132.162/27 is the firewall)
i only want to advertise the subnet of the local interface (216.224.132.160/27) when the firewall is reachable.
I have gotten it such that I can track the firewall IP's reachability using the ip sla and track functions. when I change the firewall ip to something other than 216.224.132.162 the tracking shows it as down.
But I can not figure out how to only BGP advertise the connected subnet when the firewall is reachable and not when it is down.
below is the config I currently have. please help
rtr-pittsford-rhio.roc1#sho run
Building configuration...
Current configuration : 5191 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname rtr-pittsford-rhio.roc1
boot-start-marker
boot system flash:c3825-entservicesk9-mz.124-25g.bin
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $1$QnV2$d3stnVuvqYVZKOPK18dbj1
aaa new-model
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
no ip source-route
ip cef
no ip domain lookup
ip domain name logicalsolutions.net
ip sla monitor 10
type echo protocol ipIcmpEcho 216.224.132.162
threshold 2
frequency 5
ip sla monitor schedule 10 life forever start-time now
voice-card 0
no dspfarm
track 10 rtr 10 reachability
interface Null0
no ip unreachables
interface GigabitEthernet0/0
ip address 216.224.150.18 255.255.255.248
load-interval 30
duplex auto
speed auto
media-type rj45
no keepalive
interface GigabitEthernet0/1
ip address 216.224.132.161 255.255.255.224
ip ospf message-digest-key 1 md5 7 107C21302A
ip ospf priority 0
ip ospf mtu-ignore
load-interval 30
duplex auto
speed auto
media-type rj45
no keepalive
router ospf 1
router-id 216.224.132.225
log-adjacency-changes detail
area 0 authentication message-digest
redistribute connected
redistribute static
passive-interface default
no passive-interface GigabitEthernet0/1
network 216.224.132.224 0.0.0.7 area 0
default-information originate
router bgp 65512
bgp router-id 216.224.150.18
bgp log-neighbor-changes
bgp graceful-restart restart-time 120
bgp graceful-restart stalepath-time 360
neighbor 216.224.150.21 remote-as 6983
neighbor 216.224.150.21 update-source GigabitEthernet0/0
neighbor 216.224.150.21 timers 30 90
neighbor 216.224.150.22 remote-as 6983
neighbor 216.224.150.22 update-source GigabitEthernet0/0
neighbor 216.224.150.22 timers 30 90
address-family ipv4
  redistribute static
  redistribute ospf 1
  neighbor 216.224.150.21 activate
  neighbor 216.224.150.21 soft-reconfiguration inbound
  neighbor 216.224.150.22 activate
  neighbor 216.224.150.22 soft-reconfiguration inbound
  no auto-summary
  no synchronization
exit-address-family
ip local policy route-map SONICWALL_REACHABILITY
ip forward-protocol nd
ip route 216.224.132.160 255.255.255.224 GigabitEthernet0/1 track 10
ip route 0.0.0.0 0.0.0.0 216.224.150.17
no ip http server
no ip http secure-server
ip prefix-list ADVERTISE seq 5 permit 216.224.132.160/27
ip prefix-list ADVERTISE seq 10 deny 0.0.0.0/0
ip prefix-list ADVERTISE seq 1000 deny 0.0.0.0/0 le 32
ip prefix-list RECEIVE seq 5 permit 0.0.0.0/0
ip prefix-list RECEIVE seq 10 deny 0.0.0.0/0 le 32
logging trap debugging
logging facility local6
logging source-interface GigabitEthernet0/0
logging 108.59.240.45
access-list 101 permit ip 108.59.240.32 0.0.0.31 any
access-list 101 permit ip 10.19.64.0 0.0.0.255 any
access-list 101 permit ip any any
access-list 101 deny   ip any any log
access-list 102 permit ip any 216.224.132.160 0.0.0.31
route-map SONICWALL_REACHABILITY permit 10
match ip address 102
set ip next-hop 216.224.132.162
set interface Null0
route-map OSPF-REDIST permit 1
match ip address prefix-list OSPF-REDIST
8 Replies 8
jamiegrive
Can you use the 'show ip bgp' to see if there is any change to the prefixes you have in BGP table when the object goes from Up->Down and visa versa?
thanks for the input
if I change the firewall from 216.224.132.162 to 216.224.132.163 the track shows down. and when the firewall is at 216.224.132.162 the tracking shows it as UP
I don't exactly know how to configure the BGP so it only announces the subnet only when the tracking is up and not down. I tried using a prefix list advertisement in the BGP (at one time) and it did not matter if the tracking was up or down the 3825 still advertised the subnet to the upstream BGP neighbors.
(see below snip from what I had configured)
neighbor 216.224.150.21 prefix-list ADVERTISE out
neighbor 216.224.150.22 prefix-list ADVERTISE out
I basically only want that subnet advertised when the tracking is UP as I can not rely on the interface status do to the fact there is a switch in between.
jamiegrive
Ok - no problem. Please add 'network 216.224.132.160 mask 255.255.255.224' under BGP config. It will only advertise it when the static route is in the routing table which is when the SLA is up.
The static route will never be installed in the RIB as there is already a connected route in the RIB for that same prefix (connected to Gig0/1).
If the goal is to conditionally advertise this prefix, you could just use a different prefix between the FW and the router. The FW could then use 216.224.132.160/27 for NAT and you could use the static route with IP SLA on the router as you do in the current configuration.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Ok so because it is a connected interface the BGP advertisement is always present.
How do I limit the BGP advertisement of that connected interface/subnet 216.224.132.160/27 to only when the
216.224.132.162 ip is reachable?
Hi Richard,
Well, the connected prefix is owned by the ospf process and you do redistribute ospf in bgp.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Richard,
you may use BGP conditional advertisement:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094309.shtml
You could create a static dummy route tracking the 216.224.132.162.
Then, you would use BGP conditional advertisement, which advertise (route-map ADVERTISE) the connected network if the 216.224.132.162 is reachable (route-map EXIST matching the dummy route)
Finally you would apply the config to the neighbor:
neighbor x.x.x.x advertise-map ADVERTISE exist-map EXIST
Hope this helps,
Jose.
kecorder
Since the route shows as connected it will always be advertised unless the interface goes down, there is no way to link a track to a bgp advertisent, as The other guys said The only way is to configure a static route and use The track there but you wont be able to use that subnet between The router and The firewall
