Looking for Router platform recommendation
ksnarayan43
Here are the requirements...
Router require the ability to terminate and map 200 VLANs to MPLS LSP
- This router will require the ability to receive and table up to 10,000 routes learned via RIP
- The router will require the ability to table an terminate up to 10,000 remote BGP peers
- This router will support up to xx concurrent VoIP sessions
thank you
guruprasadr
Level 7
Level 7
HI,
Cisco 7206 VXR Router (NPE-G1) Processor is the best Suited Router for MPLS based Environments and capable for processing huge routing tables and for terminating more BGP Peers.
Pls Refer link below:
http://www.cisco.com/en/US/products/hw/routers/ps341/index.html
PLS RATE if HELPS
Best Regards,
Guru Prasad R
Thank you .
How is it different from 12000 (GSR). We had issue with 12000 series routers processing 6000 RIP routes..
thanks
