MPLS-TE for VPN isn't working
John Blakley
Ok, here goes:
I have a vrf that I've configured to use a certain tunnel. I've verified that traffic is moving over the tunnel. When I put my bgp next-hop under the vrf, I lose all traffic across the tunnel. I'm running eigrp between the ce-pe, so I'm not sure if that's the problem. Does it only work with bgp peers? Here's the config on the routers, and this is in gns3:
PE-A
ip vrf Dragon
rd 100:100
route-target export 100:100
route-target import 100:100
bgp next-hop Loopback30
interface Tunnel2
ip unnumbered Loopback3
tunnel destination 9.9.9.9
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng priority 7 7
tunnel mpls traffic-eng bandwidth  512
tunnel mpls traffic-eng path-option 1 explicit name Dragon
tunnel mpls traffic-eng path-option 2 dynamic
no routing dynamic
interface Loopback30
ip address 30.30.30.30 255.255.255.255
end
ip route 19.19.19.19 255.255.255.255 Tunnel2
PE-B
ip vrf Dragon
rd 100:101
bgp next-hop Loopback19
interface Tunnel2
ip unnumbered Loopback1
tunnel destination 3.3.3.3
tunnel mpls traffic-eng path-option 1 dynamic
no routing dynamic
end
interface Loopback19
ip address 19.19.19.19 255.255.255.255
end
ip route 30.30.30.30 255.255.255.255 Tunnel2
I can ping 19.19.19.19 sourc from 30.30.30.30 and vice versa, so I believe the tunnels are passing traffic fine. Any help would be appreciated; this is irritating
HTH, John *** Please rate all useful posts ***
2 Accepted Solutions
Edison Ortiz
I haven't done this in a while and I can't test at the moment but from what I recall, you need to enable MPLS on the TE so there is a label formed for the next hop (your new loopbacks).
Yeah, I never trust those txload, rxload counters - I usually go with the packet input/output counters.
7 Replies 7
Edison Ortiz
I definitely see traffic going over the tunnel now. I enabled mpls on the tunnel interfaces, but none of the documentation that I've found mentioned doing that. The weird thing that I see now is this. From doing a ping on the CE side to another router through the mpls network, I can see the traffic going from PE-A to PE-B on the tunnel interface:
PE-A
R3#sh int tu2 | inc txload
     reliability 255/255, txload 32/255, rxload 1/255
PE-B
R9(config-if)#do sh int tu2 | inc txload
     reliability 255/255, txload 25/255, rxload 1/255
Why is PE-B showing txload also since it's the receiving side? Is this because the tunnels are one way?
Thanks Edison!
Are you pinging? It has to reply hence transmit
BTW, I'm surprised the documentation didn't include that as a requirement. You created the loopbacks in the global routing table and now they are being used as next-hop for VPNs. Usually, the next-hop is your BGP VPNv4 peer between PEs and that exchange is labeled. You need to duplicate this design with your new loopbacks.
Before applying MPLS on the TE, any traffic entering the tunnel wasn't labeled so when you created the static route and pointed to the tunnel, a label was not formed.
You can verify with the show mpls forwarding command and you will see labels for the bgp next-hop on each router.
Um, yeah Wouldn't I be seeing receive on the other side also?
Are you talking about the 5 minute counters? My output is the only thing increasing for both sides. Oh well, it's working...
PE-A:
  5 minute output rate 248000 bits/sec, 32 packets/sec
PE-B:
  5 minute output rate 241000 bits/sec, 29 packets/sec
My counter is increasing to the customer side that I'm pinging that belongs to the same vrf:
CE-B
  reliability 255/255, txload 53/255, rxload 53/255
Edison Ortiz
As expected due to the unidirectional behavior with MPLS TE
