08-15-2021 12:27 PM
How loops created in OSPF and how to avoid it
08-15-2021 12:46 PM
many case found, and good design is the solution.
08-15-2021 12:53 PM
Most Loops you see in any routing Protocol - redistribution(different case BGP), so avoid redistribution or use Route-map or Tag while you doing so.,
08-15-2021 12:58 PM - edited 08-15-2021 01:00 PM
Dear @balaji.bandi
Can you please draw a simple topology to explain the point that how loop create in loop please. Thanks
08-15-2021 01:10 PM
Not sure what IGP Protocol you looking for ( have you google it ?)
here is a good explanation that can help :
08-15-2021 05:02 PM
Perhaps the most common way for a (transient) loop to form is during convergence, when all the routers do not have "current" topology.
This often happens when a "bad news" route change has taken place, like a dropped link.
For example consider router A has a link to routers B and C, both of those having a link to router D. Router A considers the path to router D "better" via router B than using router C. However, routers' B and D link fails, which routers B and D know first. If router B bounces traffic back to router A, while router A still considers router B the best path, you would have a transient loop.
08-16-2021 06:34 PM - edited 08-16-2021 06:59 PM
First of all, OSPF Unique Router ID is first thing that protects loop forming among other things. Among Intra Areas, we have same database and filtering is not allowed. I mean you cannot filter LSA1 or type 2 from database but you can filter those from getting into the IP route table (RIB). But, you can filter types 3 and 5 from other areas and between areas. For Inter-Area routes and areas, OSPF uses distance-vector logic and principle (split horizon rule). The main OSFP area concept that also helps avoiding loops (unlike distance-vector protocols) is the fact that other areas must be connected to Area 0, aka backbone area, either physically or via Virtual link. In case of multiple Inter-Areas, OSPF has major rule that is often forgot: if ABR learns a Type 3 LSA inside a non-backbone area, that ABR ignores this type 3 LSA when calculating its own routes. This prevents loops when you have 2 ABRs connecting the same Area X to Area 0. Other thing is that we have per-determined order of selection: intra-area routes are preferred over Inter Area-routes regardless of metric/cost. This behavior cannot be change for good reasons.
Regards, ML
**Please Rate All Helpful Responses **
