loops scenarios in ospf
rocky2024
I am trying to locate OSPF loops case studies, how they occur in the network ?
i can see many post about how to prevent it but I want to read more how loops occur in the network?
please help me
rocky2024
do you run lab for ospf loop ?
balaji.bandi
The document INE produced good document for reference. - have used for my Lab purpose when I was giving Lab.
Cisco has good document (quite old but good to read - if you starting the initial level of understanding OSPF)
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/7039-1.html#t5
The major case you see where the Loop occurs were when you redistribute between IGP, and also loop in the network design. ( you can eliminate using ACL to block - so loop can avoid)
in the case of BGP that will be taken care of intelligently.
BB
