Losing my eigrp route table every 24 hrs.
jomo frank
Hello Expert,
I have three routers connect hub using pppoe , I notice after 24 hr elapses I am losing my eigrp routes.(when I do show route the are no entries ) This issue is happening to only one of my spoke routers.
In order to re populate the eigrp routing table a I just issue a shutdown wait a few seconds and then no shutdown on  the dialer interface.Once I do this the eigrp table is re-populate .
I did a show log and the error below was notice.
: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet ha
s invalid spi for destaddr=10.252.248.xx, prot=50, spi=0x1AD290A7(450007207), s
rcaddr=10.252.248.xx, input interface=Dialer
Could anyone provide some guidance.
21 Replies 21
Hello Georg,
Thanks for pointing this out ---- nothing beats an expert eye.
I made the adjustment on the spoke, I guess I have to wait for the 13.16 pm tomorrow for the confirmation if this modification fix the issue.
Do see any other issues with the configs in the current state?
Is the config (exactly) the same on the other spokes that DO work ?
Hello Georg,
The config are the same but I have the  crypto isakmp keepalive 60 periodic  on the other spokes but they  still works.
If the issue still continue tomorrow I plan to build another router using the config from a working spoke, remove the problematic router and hope for the best.
This one has really stomp me.
Hello Georg,
Install a new router with configs  from a working spoke but same result after 24 hrs  eigrp  tunnel drops and fail to re-establish.
Any new lead to resolve this problem?
Hello Deepak,
Some addition info about the sla ------- I config the sla this morning.the results show was collect after the router reloaded.
ip sla 111
icmp-echo 172.26.10.2 source-interface Dialer0
frequency 10
ip sla schedule 111 life forever start-time now
IPSLA operation id: 111
Latest RTT: 1 milliseconds
Latest operation start time: 13:35:10 Caracas Sun Feb 24 2019
Latest operation return code: OK
Number of successes: 71
Number of failures: 3
Operation time to live: Forever
The three failures relates to the period the router took to reload
on a side note, try and configure the spoke as a static EIGRP neighbor on the hub (and the hub as a static EIGRP neighbor on the spoke), and check if that makes a difference:
HUB & SPOKE
router eigrp x
neighbor x.x.x.x
Hello Georg,
You mean the wan interfaces of the spoke and hub
Should I do s separate eigrp or can include same the existing eigrp 100 ?
example
THE HUB
eigrp 100
network 10.252.248.55
SPOKE
eigrp 100
network 10.252.248.131
