LOSS CONNECTION ---- FRAME-RELAY TO ATM (FRF.8)
leandro.candido
Hello all,
I am with problem that sometimes the comunication is lost, the lik was working propelly but suddenly the comunication get down. When I access the router by console and I remove the virtual-template and change the ppp protocol for IETF, and the other end change for aal5nldpid, the link become UP.
I have the follow topology:
frame-relay ---> telco ---> ATM
end satation end station
CONFIG FRAME-RELAY
interface Serial0/0.1 point-to-point
description INTERFACE FRAME-RELAY END STATION
bandwidth 128
ip address
ip nbar protocol-discovery
ip ospf cost 170
frame-relay interface-dlci 21 ppp Virtual-Template1
class 128k
interface Virtual-Template1
description MLP INTERFACE VIRTUAL FRAME-RELAY END STATION
bandwidth 128
ip unnumbered Serial0/0.1
ip tcp header-compression iphc-format
ip ospf cost 170
ppp multilink
ppp multilink fragment delay 10
ppp multilink interleave
service-policy output 128k_4ch
ip rtp header-compression iphc-format
CONFIG ATM
interface ATM1/0.13 point-to-point
description ATM END STATION
bandwidth 128
ip address
ip accounting output-packets
ip ospf cost 170
pvc 2/77
protocol ip
vbr-nrt 155 155 1
tx-ring-limit 3
encapsulation aal5autoppp Virtual-Template113
interface Virtual-Template113
description Interface Virtual END STATION ATM
bandwidth 128
ip unnumbered ATM1/0.13
ip ospf cost 170
ppp multilink
service-policy output 128K_4CH
Someone known what could cause this problem?
Someone suggest something?
Thanks for your help
5 Replies 5
paolo bevilacqua
Which IOS are you using, and does it work if you reload the router with the PPP configuration ?
IOS is C3745-JSX-M.12.3.19.
Same doing reload the comunication is not working.
I did test now and note that if I creat the new virtual-template and sub-interface, the link back working.
I think that problem could be in virtual-access....
You can be running into a bug, can you upgrade to latest image of 12.3 or 12.4 and try again ?
What type of bug? Do you known??
A bug that causes the symptoms you are seeing - at reboot with correct config doesn't work, then you configure it again and it starts working.
