- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-17-2019 06:09 PM
Hi Everyone,
I am kinda lost at the moment on why I am facing this issue and was hoping I could get someone to explain to me why this is happening.
Below is the simple network diagram of the issue I am facing.
I believe this has something to do with route-reflectors (I may be wrong).
I do not have any P routers in my environment at the moment.
In my MPLS network, I have different VRFs that is spanned between the PEs.
North_PE and South_PE are both Route-reflectors and SiteA_PE is a route-reflector-client of North_PE.
The issue faced is from SiteA_PE routing table for the different VRFs, I am only seeing a subset of routes for each VRFs and these routes are the ones that are local to North_PE.
I am NOT able to see routes that are beyond North_PE (i.e. local to South_PE).
BGP Configuration - North_PE
router bgp 65000
bgp-cluster id 1.1.1.1
neighbor PeerGroup1 peer-group
neighbor PeerGroup1 remote-as 65000
neighbor PeerGroup1 update-source Loopback0
neighbor PeerGroup1 soft-reconfiguration inbound
neighbor PeerGroup2 peer-group
neighbor PeerGroup2 remote-as 65000
neighbor PeerGroup2 description "RR_Client"
neighbor PeerGroup2 update-source Loopback0
neighbor PeerGroup2 soft-reconfiguration inbound
neighbor 2.2.2.2 peer-group PeerGroup1
neighbor 3.3.3.3 peer-group PeerGroup2
address-family vpnv4
neighbor PeerGroup1 send-community extended
neighbor PeerGroup2 send-community extended
neighbor PeerGroup2 route-reflector-client
neighbor 2.2.2.2 activate
neighbor 3.3.3.3 activate
exit address-family
BGP Configuration - SiteA_PE
router bgp 65000
neighbor 1.1.1.1 peer-group
neighbor 1.1.1.1 remote-as 65000
neighbor 1.1.1.1 update-source Loopback0
neighbor 1.1.1.1 soft-reconfiguration inbound
neighbor 1.1.1.1 send-community extended
neighbor 1.1.1.1 activate
exit address-family
Is there anyone that could advise me if I have done my configuration wrong?
Thanks.
Solved! Go to Solution.
- Labels:
Other Routing
Routing Protocols
WAN
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-21-2019 07:41 PM
Thanks for your assistance.
It turns out that on the North_PE, I need to put a command "neighbor PeerGroup2 next-hop-self all" for vpnv4.
Once that config is in, all routes are redistributed via the RR.
Han
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-17-2019 08:53 PM
North-PE should be your route reflector and client + South-PE are route reflector client.
Afterwards, every prefixes should be exchanged.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-21-2019 07:41 PM
Han
