lost cell delineation
ciscoenter
Hello all,
I'm using a cisco 2811 IOS c2800nm-entservicesk9-mz.124-5.bin with 4 VWIC-2MFT-E1 modules connected with eight E1 atm link configured with 2 ima groups.
Even if i've replaced wic and cables i continue to receive these error:
*Aug 29 13:50:19.614: %ATM_AIM-5-CELL_ALARM_UP: Interface ATM0/2/0 lost cell delineation.
*Aug 29 13:50:19.630: %ATM_AIM-5-CELL_ALARM_DOWN: Interface ATM0/2/0 regained cell delineation.
*Aug 29 13:50:20.130: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
*Aug 29 13:50:20.130: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
*Aug 29 13:50:20.158: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
and for all the interface grouped to the same ima group.
here the configuration:
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-participate aim 0
network-clock-participate aim 1
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
network-clock-select 3 E1 0/2/0
network-clock-select 4 E1 0/3/0
controller E1 0/0/0
mode atm aim 0
controller E1 0/0/1
mode atm aim 0
controller E1 0/1/0
mode atm aim 0
controller E1 0/1/1
mode atm aim 0
controller E1 0/2/0
mode atm aim 1
controller E1 0/2/1
mode atm aim 1
controller E1 0/3/0
mode atm aim 1
controller E1 0/3/1
mode atm aim 1
interface ATM0/IMA0
no ip address
load-interval 30
ima clock-mode common 0
no atm oversubscribe
no atm ilmi-keepalive
service-policy output VOICE-POLICY
interface ATM0/IMA0.1 point-to-point
description WORKING
ip address 192.168.1.6 255.255.255.252
ip mtu 1500
ip load-sharing per-packet
no snmp trap link-status
pvc 11/100
protocol ip 192.168.1.5 broadcast
ubr 7680
oam-pvc manage
encapsulation aal5snap
interface ATM0/IMA1
no ip address
load-interval 30
interface ATM0/IMA1.1 point-to-point
description NOT WORKING
ip address 192.168.1.2 255.255.255.252
ip mtu 1500
pvc 11/100
protocol ip 192.168.1.1 broadcast
ubr 7680
oam-pvc manage
interface ATM0/0/0
no ip address
scrambling-payload
ima-group 0
interface ATM0/0/1
no ip address
scrambling-payload
ima-group 0
interface ATM0/1/0
no ip address
scrambling-payload
ima-group 0
interface ATM0/1/1
no ip address
scrambling-payload
ima-group 0
interface ATM0/2/0
no ip address
scrambling-payload
ima-group 1
interface ATM0/2/1
no ip address
scrambling-payload
ima-group 1
interface ATM0/3/0
no ip address
scrambling-payload
ima-group 1
interface ATM0/3/1
no ip address
scrambling-payload
ima-group 1
These two links are provided by the local incumbent but i don't know if they are attached to the same device;
If the two links are connected to a different device, is it possible that the second link use le clock of
the first one losing delineation?
Thanks in advance
purohit_810
Level 5
Level 5
See as of error's mean: %ATM_AIM-5-CELL_ALARM_UP: Interface ATM0/2/0 lost cell delineation.
If the alarm or the interface is flapping, check the clocking configuration.
PLEAE CHECK YOUR CKOCK CONFIGURATION. NO ACTION REQUIRED ON Interface ATM0/2/0 regained cell delineation.
http://www.cisco.com/en/US/products/ps6350/products_system_message_guide_chapter09186a0080462670.html
Dharmesh Purohit
