%% Low on memory; try again later
MErskine
Getting this message on the console of a 7204 router. Is there any way to reload without powering off? If so, how? Also, what is causing this issue? Thanks in advance.
-Process= "
0B754 0x60F0BFBC 0x60F0C2186000ADD8 0x
Alternate Pool:
064722: Dec 1 19:21:52.033 UTC: %SYS-2-MALLOCFAIL: Memory allocation of 65536 b
Pool: Process
-Process= "CCSIP_SPI_CONTROL", ipl= 0, pid= 159EF6034 0x60EF6EF4
ytes failed from 0x60029860, alignment 8= 0x610CBDDC 0x6000ADD8 0x6000FEE8 0x600
Pool: Processor Free: 2132776 Cause: Memory fragmentationx60DFA830
15 Replies 15
which IOS version are you running ? Could be a bug, but either way, unfortunately the only way to resolve these memory leaks is a reboot. What is the uptime of the router (sh ver) ?
Giuseppe Larosa
Hello @MErskine ,
if even console access is not possible your only option is to power off the C7204 to reload it.
The issue is caused by a software defect in a process that causing memory leakage has consumed all the available memory.
You need to monitor avaialble memory on the device.
Hope to help
Giuseppe
MErskine
I have console access but cannot do anything. All I get it the low memory error when I press enter.
DeShark
Hello @MErskine ,
yes I see you have console access but the router is so short of memory to be unable to allocate it to manage the console connection this is the meaning of the message and when this happened to me I had to power cycle the device.
I don't see any other option to reload it at this point.
Hope to help
Giuseppe
Leo Laohoo
Once that message appears, it is usually a sign that the appliance is no longer "manageable" or non-recoverable.
In every instance, the only workaround is to reboot the appliance.  For a permanent fix, upgrade the firmware.
MErskine
Ok I power cycled the router and it is back online. I am running a 7204VXR router. Here is sh ver..
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9-M), Version 12.4(2)T, R
ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 23-Jun-05 20:25 by kellmill
ROM: System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVEL
OPMENT SOFTWARE
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(6f), RELEASE SOFTWARE (fc1)
@MErskine wrote:
12.4(2)T
A 7200VXR is a very critical router and running a "T" train IOS is NOT recommended.  Double-jeopardy:  Not only is the router running a "T" train firmware but a "release 0".  An "M" train is more recommended.
Strongly recommend you think about getting the firmware upgraded.
What does the "T" and "M" stand for? Where can I find these downloads so I can update this?
Cisco calls the "T" train as "technology".  People who got badly burnt by this call it the "terrible".   Use "T" train releases with extreme caution.
"M" train is called "Maintenance" and it is alot more "stable" and recommended for long-term use.
Thank you. Good to know. Where can I download updated versions?
Go HERE.
NOTE:
7200 chassis is about to hit end-of-support date.  Download the files ASAP before they are permanently removed from the download site.
Thanks but it won't let me dl any files. Says I need a service contract to dl files. Seriously? No support for their own hardware? Any suggestions?
That is normal.  It is not a Cisco "thingy" -- This is an industry-wide practice.
I will inquire about it. They list several code bases.. how do I choose the right one? Here is the list...
ADVANCED ENTERPRISE SERVICES
ADVANCED ENT SERVICES W/SNA SWITCH
ADVANCED IP SERVICES
ADVANCED IP SERV W/LAWFUL INTERCEPT
ADVANCED SECURITY
IP BASE W/O CRYPTO
IP BASE
SP SERVICES
