how do i create acl for ssh radius authentication
lightning668
Frequent Visitor
Frequent Visitor
Hi, how do I create ACL to only allow certain routers to access the radius server for aaa authentication with radius server login . i tried implementing
Changi(config)#access-list 100 permit tcp 10.0.0.124 0.0.0.3 10.0.0.96 0.0.0.15 eq 22
but it doesn't seem to allow login with radius server users.
should the destination host be the radius server IP address or the network address of the subnet that consist of the radius server?
Thanks in advance
Georg Pauwen
what RADIUS ports do you have specified ? Most recent RADIUS implementations use:
UDP/1812 --> authentication/authorization
UDP/1813 --> accounting
or, on older implementations:
UDP/1645 --> authentication/authorization
UDP/1646 --> accounting
Georg Pauwen
Mark Elsen
 - Try the example (albeit modified for your subnet) , from this link :
               https://www.certificationkits.com/cisco-certification/ccna-articles/cisco-ccna-access-lists/configuring-telnet-a-ssh-via-an-acces-list/
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
