Low Quality & Packet Drops On DSL ATM
Elie Bassil
I have a scenario with DSL line connected to HWIC-1ADSL-M card, I am facing some packet drops (WAN-to-WAN ping tests) and very low bandwidth. The provider already checked the line and saw no issues in it (but I am still doubtful about that). I am also getting the below error on the router, is there any way to conclude from the below outputs any problem with the HWIC card...?
Sep 24 07:30:55.582: (ATM0/0/0): CRC error in rcvPakFrame, vcd = 1, pkt len = 480, num of cells = 10, buf_addr = 0xE031AC0, vpivci = 0x23, w3 = 0xED992929, w4 = 0x7C80B20A
Sep 24 06:19:10.033: ATM0/0/0 dslsar_ng_periodic Could not get the atm_vc_info_t, vcd=14
I have the below configuration:
interface ATM0/0/0
bandwidth 1000
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
description ---
mtu 1500
bandwidth 1000
ip address ---
ip access-group 5 out
no ip redirects
no ip unreachables
no ip proxy-arp
atm route-bridged ip
pvc 0/35
  encapsulation aal5snap
------------------ show dsl interface ------------------
ATM0/0/0
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ANSI T1.413
ANSI Issue/rev:  2/1                             2/1
Vendor ID:       0x003A                          0x0054
Chip ID:         C196 (3) capability-enabled
DFE BOM:         DFE3.0 Annex M (3)
Capacity Used:   51%                             28%
Noise Margin:    13.0 dB                         27.0 dB
Output Power:    15.0 dBm                        11.5 dBm
Attenuation:     67.0 dB                         31.5 dB
FEC ES Errors:    0                               0
ES Errors:       235                              8
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0xBF
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      107129 (0 spurious)
PHY Access Err:  0
Activations:     10
LED Status:      OFF
LED On Time:     0
LED Off Time:    0
Init FW:         init_AMR-4.0.015_no_bist.bin
Operation FW:    AMR-4.0.015.bin
FW Source:       embedded
FW Version:      4.0.15
                 Interleave             Fast    Interleave              Fast
Speed (kbps):           512                0           128                 0
Cells:               292116                0        592427                 0
Reed-Solomon EC:       7834                0             0                 0
CRC Errors:               7                0             1                 0
Header Errors:            4                0             0                 0
Total BER:                1302E-9                0E-0
Leakage Average BER:      1302E-9                0E-0
Bitswap:               enabled            enabled
Bitswap success:          0                   0
Bitswap failure:          0                   0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 0 2 3 4 4 4 4 4 4
010: 0 3 3 3 3 3 3 2 2 2 2 2 2 2 2 0
020: 0 2 2 2 3 2 3 3 3 3 4 4 4 4 4 3
030: 3 4 3 3 2 2 2 0 0 0 2 2 4 4 4 4
040: 0 5 3 3 3 0 2 4 2 4 4 4 4 3 3 3
050: 3 3 3 2 2 4 4 3 2 3 3 3 2 2 3 2
060: 3 3 0 0 0 0 2 2 2 0 0 0 0 0 0 0
070: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
080: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
090: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0A0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0B0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
------------------ show interfaces ------------------
ATM0/0/0 is up, line protocol is up
  Hardware is HWIC-DSLSAR (with Alcatel ADSL Module), address is 8843.e116.ef43 (bia 8843.e116.ef43)
  MTU 4470 bytes, sub MTU 4470, BW 1000 Kbit/sec, DLY 4000 usec,
     reliability 255/255, txload 4/255, rxload 8/255
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  23 maximum active VCs, 256 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input 00:00:04, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4893
  Queueing strategy: Per VC Queueing
  5 minute input rate 32000 bits/sec, 10 packets/sec
  5 minute output rate 18000 bits/sec, 9 packets/sec
     1130915 packets input, 451271319 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 59 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1144273 packets output, 245094560 bytes, 0 underruns
     0 output errors, 0 collisions, 9 interface resets
     5123 unknown protocol drops
ATM0/0/0.1 is up, line protocol is up
  Description: ---
  Internet address is 192.168.241.17/24
  MTU 1500 bytes, BW 1000 Kbit/sec, DLY 4000 usec,
  Encapsulation ATM
     1130917 packets input, 451340905 bytes
     1144274 packets output, 245095236 bytes
     0 OAM cells input, 0 OAM cells output
  AAL5 CRC errors : 0
  AAL5 SAR Timeouts : 0
  AAL5 Oversized SDUs : 0
------------------ show version ------------------
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 02-Dec-09 15:23 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M1, RELEASE SOFTWARE (fc1)
-- uptime is 2 days, 7 hours, 28 minutes
System restarted at 05:57:39 LEB Wed Sep 21 2011
System image file is "flash:c2900-universalk9-mz.SPA.150-1.M1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 475136K/49152K bytes of memory.
3 Gigabit Ethernet interfaces
2 Low-speed serial(sync/async) interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
Let me know if any additional output is needed.
thanks,
E.B:.
johnlloyd_13
Level 9
Level 9
hi EB,
you've got a very high line attentuation. kindly report this again to your SP. you also got CRCs. replace RJ11 and monitor again. if it's still increasing, ask your SP to re-punch or re-terminate the line.
