LSP Establishment Method
abdul.qadir5001
An LSP can be established by manually establishing hops or by the label distribution protocols. Is this a right statement
Giuseppe Larosa
Hello @abdul.qadir5001 ,
yes it  can be accepted , when we specify an explicit path we are talking of LSPs that are setup by RSVP TE , the only standard label distribution protocol is LDP   ( the old Cisco TDP is not supported anymore).
However, an MPLS TE tunnel with no explicit path will use a dynamic path in this case RSVP TE acts as a label distribution protocol for this LSP and will find a path that satisfy the FLOWSPEC parameters (bandwidth)
Hope to help
Giuseppe
that statement is correct. LSPs can be either static or dynamic.
Have a look at the link below, which explains it very well I think...
https://support.huawei.com/enterprise/en/doc/EDOC1100055043/78868833/lsp-establishment
