Mac address Flapping on Catalyst 3850
bergonzoni
Hi all, I have a couple of Catalyst 3850 Switches, if I connect them with a Port-channel I have many Mac address Flapping events and resulting problems on virtual-machines attached to them.
The Port-channel can be of one or more active links but I have the same issue, if I remove this Port-channel and replace it with a single link I don't
have this issue.
In both cases this link between 3850 is correctly blocked by STP.
I suspect that I have a wrong configuration on Switches of Vmware Infrastructure but I don't understand why the single link works and Port-channel doesn't work.
I tried LACP and Static etherchannel but I have the same issue.
Marco Bergonzoni
swillet41
bergonzoni,
I have a simliar issue, but only with a 2960-48port switch.  I am using c2960-lanbasek9-mz.150-2.SE8.bin
Did you ever resolve your issue?
What IOS are you using?
Scott
