BGP Advertise default
opnineopnine
Hi all.
I have a doubt I need to advertise only my default route via BGP.  I have the following configuration example
ip prefix-list DEFAULT permit 0.0.0.0/0
route-map DEFAULT permit 10
match ip address prefix-list DEFAULT
ip route 0.0.0.0 0.0.0.0 Null0
router bgp <AS>
network 0.0.0.0 mask 0.0.0.0
neighbor <CUSTOMER_PEER_IP> route-map DEFAULT out
Will this let me do the job, or I need to add something else?
Thanks.
7 Replies 7
John Blakley
There's an easier way to do this if you're just wanting to advertise their peer address as the default:
neighbor <neighbor address> default-originate
HTH,
John
HTH, John *** Please rate all useful posts ***
Hello John,
This is what Im looking for I have my mpls with 4 different ISP and I only want to send them my default route.
Thanks.
Ah gotcha...okay, so the policy you have should work for that if you're wanting to control what the ISP sees...
John
Is I use the option
ip as-path access-list 10 permit ^$
thanks.
That's going to advertise your locally advertised routes. Your first solution is better for what you were wanting to do...
To see what I mean, you can do the following on your router:
show ip bgp regex permit ^$
Yes I know it will only advertise the local routes, the customer wants to makes this change but my question is, I only have to advertise the 172.20.230.0 255.255.255.0
router bgp xxxxx
nei 192.168.23.2 filter-list 1 out
thanks!
I would create a prefix list to advertise it..With you as-path acl, you could be advertising more than just that...
