MAC Address Spoofing Can I Do it on a Cisco Router?
eric_clapp
Please help,
I have a Cisco 871W router and need ideally to spoof the mac address of me previous router to avoid changing the DNS records for my domains.
Any advise would be greatly appreciated.
Richard Burts
Nic
I am not familiar with the 871W router. But most IOS based routers give you the ability to change the MAC address of interfaces that have a MAC. Check in interface configuration mode and see if there is a command "mac-address". If it is there it should give you the ability to have the router use the MAC address of your previous router instead of the burned in address of your new router.
Rick
Rick
Richard Burts
Nic
Rick
Rick
