MACsec Router to Switch
xpapapavlou
"Is MACsec supported between a Cisco 8000 series router equipped with a C-NIM-2T-WAN module (or another recommended optical Layer 3 module... suggest one...), using sub interfaces in a router-on-a-stick configuration, and a Layer 2 Cisco switch connected via a trunk port?"
Jan Rolny
Level 3
Level 3
yes, as per datasheet C-NIM-2T supports MACsec. Please check this article how to configure MACsec on subinterface:
https://www.cisco.com/c/en/us/td/docs/iosxr/cisco8000/security/711x/configuration/guide/b-system-security-cg-cisco8000-711x/configuring-macsec.html
Also be sure that your L2 switch support MACsec also otherwise it will not work.
Best regards,
Jan
Thanks a lot !!
