Mark DE and generate BECNs and FECNs in FR lab
TYLER WEST
I have built a small FR lab for testing QoS configurations prior to production implementation. I have FR switching set up no problem. However, I want to simulate some congestion to cause DE packets to be dropped and BECNs and/or FECNs to be generated. Causing the congestion was no problem. I can easily back up the queues and force drops on the PVCs. However all of my PVC stats show 0 BECNs or FECNs on the end routers and the FR switch. How can I get it to mark those packets accordingly?
Tyler
rabeder
do you use a "real" fr-switch or do you use a cisco-router as a fr-switch?
if a cisco-router acts as a fr-switch it does not
(by default) send becn/fecn.
if it should do so, you have to configure congestion-management
