configured router 2600 & 1700 with comm on serial interface,compression stac.
showing u configuration on both sides,
2600
Serial1/6
Software compression enabled
uncompressed bytes xmt/rcv 3478916/3405061
compressed bytes xmt/rcv 0/0
1 min avg ratio xmt/rcv 2.550/1.974
5 min avg ratio xmt/rcv 2.220/1.322
10 min avg ratio xmt/rcv 2.277/1.382
no bufs xmt 0 no bufs rcv 0
resyncs 3
Additional Stac Stats:
Transmit bytes: Uncompressed = 20667 Compressed = 1294812
Received bytes: Compressed = 1739001 Uncompressed = 647044
1700:
Serial0/0
uncompressed bytes xmt/rcv 3644985/3755968
1 min avg ratio xmt/rcv 1.624/2.522
5 min avg ratio xmt/rcv 1.347/2.261
10 min avg ratio xmt/rcv 1.396/2.307
resyncs 3
Transmit bytes: Uncompressed = 665926 Compressed = 1856010
Received bytes: Compressed = 1431228 Uncompressed = 22555
pls tell whether its working or not,,,,should i use diff algo for compression.
if its working,how to verify that ,i mean which statement tells tht.
