Marking FE traffic for QOS process
locus2007
Hallo,
I need mark traffic from specific FE switch port on C1802 when in goes thrue Dialer there is done some Qos process.
How can I do this on FE 8 if all ports are in BVI1?
I tryed IP based marking that is not good in case of DHCP clinets off course.
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
  no ip address
  bridge-group 1
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 192.168.X.X 255.255.255.0
no ip redirects
no ip unreachables
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip tcp adjust-mss 1452
bridge 1 protocol ieee
bridge 1 route ip
Urbanek
17 Replies 17
giuslar wrote:
I think the problem is that Fas6 is a port of an etherswitch module in an ISR router.
Probably QoS features are not supported on Etherswitch ports.
According to the documentation:
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_enet_switch_net_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1130377
QoS is supported on etherswitch modules with some caveats. One of those caveats is the class class-default isn't supported.
With that said, we can modify my previous recommendation as followed:
class-map DSCP-EF
match any
policy-map DSCP-EF
  class DSCP-EF
   set dscp ef
interface fastethernet 6
  service-policy input DSCP-EF
Edison
Giuseppe has illustrated the requirements for QoS marking, thanks Giuseppe.
You can verify if that interface does run CEF with the 'show ip cef fastethernet 6' command.
You mentioned about applying the ingress policy on the BVI - you could do that but it won't target the information on per-switchport basis.
I'm not sure if you can match on interface with this hardware but it's worth a try.
class-map DSCP-EF
  match input-interface fastethernet 6
policy-map DSCP-EF
  class DSCP-EF
    set dscp ef
interface BVI
Edison
I have try it end no success with class test
Router#show policy-map interface bvI 1
BVI1
  Service-policy input: policy_mark
    Class-map: class_reznik (match-any)
      168709 packets, 20827818 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name access_reznik
        5 minute rate 0 bps
      QoS Set
        dscp ef
          Packets marked 168709
    Class-map: class_honza (match-any)
      112818 packets, 9869099 bytes
      Match: access-group name access_honza
        5 minute rate 0 bps
      QoS Set
        dscp af12
          Packets marked 112818
    Class-map: test (match-all)
      0 packets, 0 bytes
      Match: input-interface FastEthernet6
      QoS Set
        dscp af21
          Packets marked 0
    Class-map: class-default (match-any)
      146312 packets, 21565553 bytes
      Match: any
and on FE6 the traffic was
Router#show interfaces fastEthernet 6
FastEthernet6 is up, line protocol is up
  Hardware is FastEthernet, address is 0021.5556.35d5 (bia 0021.5556.35d5)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 1d16h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     19154 packets input, 1872292 bytes, 0 no buffer
     Received 388 broadcasts, 0 runts, 0 giants, 0 throttles
     47318 packets output, 19757094 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
and post before not succes too
Router#show policy-map interface fastEthernet 6
FastEthernet6
  Service-policy input: test_in
      0 packets, 0 bytes
      Match: any
      QoS Set
        dscp af21
          Packets marked 0
      0 packets, 0 bytes
      Match: any
As you see I use ip based marking that work for me now, but it is not solution to marking all interface traffic.
