Max cable length for G.703
d-fillmore
Level 2
Level 2
Hi, I've got a circuit that is terminated using BNC connectors in a comms cabinet. The router is going to be installed about 15 meteres away.
What would be the best cable to use for this? I'm thinking I could use a CAB-E1-BNC, a 15m patch lead and a coupler to join them together. Would this be viable? or is there a better option?
Many Thanks in advance, Dom
paolo bevilacqua
yes, the best would be coax extenders to the cable ends. Your are within the max length by a factor of like 10.
Hi - Thanks for your response. I think I got the cable part number wrong. There is a Cisco part which is a BNC to RJ45 convertor. I want to connect that end to the cirucit termination points, then join the other end to a long patch lead using a coupler, then plug the patch lead into the WIC-1MFT-E1
If you are talking about the conversion, a "balun", is a passive electronic device that converts between RJ-48(120ohm) and BNC(75ohm).
And any way here you are the part number of most of cisco cables:
http://www.cisco.com/en/US/products/hw/routers/ps332/products_tech_note09186a0080094b45.shtml
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
