Max performance ATM OC3
mmasis
Level 4
Level 4
What's the max performance an ISR 3800 can get with an ATM OC3 module?
Is 155Mbps?
Thanks in advance!
paolo bevilacqua
First of all, you have atm overhead, makes a 155 mbps to be really 120 mbps or so.
http://sd.wareonearth.com/~phil/net/overhead/
Secondly, a 3845 might get close to max circuit utilization, but with significant CPU usage.
A 3825 would probably melt much before.
hope this helps, please rate post if it does!
I really appreciate your effort, but i found it in a presentation on CEC; ISR are CPU based so it could reach higher performance, but basically the answer was yes.
Thanks!!! have a greate weekend!
Here's attached "your" official numbers.
As you see for smaller packet size linerate cannot be reached. So in general don't count on a 3825 to be able "to fill the pipe" and still have CPU to spare. It won't.
Thanks for the attached file is very helpfull.
