Maximum file size on a 256MB Compact Flash Card
mikeleecha
Hello. Does anyone know if there's a maximum file size supported on the 256 MB compact flash cards that go with the ISR routers?
I've been trying to upload some newer code on my routers and whenever the transfer hits 33,546,240 bytes the transfer stops.
I've tried this on mulitple tftp servers and I get the same result. I've also tried it on multiple ISR routers I have an get the same problem
mheusinger
Level 10
Level 10
unfortunately with many TFTP servers there is a 32 MB file size limit. You can use FTP to load the image or use TFTPd32, which should work with larger files as well. http://tftpd32.jounin.net/
Hope this helps
Martin
