Maximum log buffer sizes
Eric Marshott
Frequent Visitor
Frequent Visitor
Syslog is great, but it is much easier in a pinch to see log messages right in console/buffer.
Is it safe practice to use the maximum log buffer size shown in Cisco IOS and IOS-XE?
 -3850 running 3.6.6 shows range of value for `logging buffered ` as 4,096-2,147,483,647
Where is log buffer stored on the device?
 -i dont see any files in any of the filesystems that are the same size as my max-sized log buffer
If the log buffer gets too large, could it overload the management plane?
Much appreciated
-Eric
15 Replies 15
Joseph W. Doherty
I believe syslog and console buffer are both stored in RAM.  So, the only issue with increasing their size would be to limit the RAM available to other system needs.  Which, if the network device doesn't have a need for that RAM, shouldn't create any problem.
What I don't know is whether RAM is immediately set aside when configured for a specific size or whether it's allocated as needed.  (I suspect the latter.)
BTW, console output could cause high CPU usage.  I.e.:"
Possible Causes of High CPU Utilization Due to Interrupts
High CPU utilization on an interrupt level is primarily caused by packets handled on interrupt level. Interrupts are generated any time a character is output from the console or auxiliary ports of a router.
"  Don't know if this still holds, but if it does, it would be best to avoid doing console logging.
