BGP Sessions on router
Hi all, I am wandering, if the worry is having to many BGP Sessions on Router A, is there are any difference between the following 2 scenarios? If there are no differences, is there a BGP feature that helps overcoming this problem?
Scenario 1:
Scenario 2:
 Thanks in advance for any help
Davide
since these are all eBGP session, the only thing I could think of are peer groups. Route Reflectors and Confederations won't help (and work), since there is no need for a full mesh in eBGP.
https://networklessons.com/bgp/bgp-peer-groups-on-cisco-ios
6 Replies 6
Vpnv4 is better
config one bgp between routers and inject vrf route
balaji.bandi
If the peers are many suggested to use RR ( Route Reflector) for redundancy. with BGP vpnv4
example : vpnv4
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/xe-16/irg-xe-16-book/bgp-vrf-aware-conditional-advertisement.html
BB
Thanks, the fact is that routers B,C,D will have eBGP sessions with router A, that's why I was wondering if there are any similar features like Route Reflector to use for eBGP.
Many thanks
David
balaji.bandi
Router A  is your control, you can also look templates.
BB
Many thanks Georg, very helpful
Davide
