maximum number of ssid for 1600 ap
mireille.saade
Dear support,
kindly advise what the maximum number of SSID supported on aironet 1602
best regards
Sandeep Choudhary
Hi Saade,
MAX WLAN or the SSID that u can go on a AP is 16.
Depending on the firmware, typically a WLC can support up to 16 SSID.
Reagrds
Sandeep Choudhary
Hi Saade,
Reagrds
great. thank you
If you are satisfied with the answer then can u plz mark as answered and also plz rate the post.
Doesn't make any difference.  If you enable 16 SSID per AP then your channel get over-utilized, which is not good.
Consider shrinking your SSID to 4 and below.
