Maximum Practical Bandwidth Support on WIC 2AS card on 1841 Router.
ranjit123
Level 3
Level 3
Dear All,
Kindly Update me the Practical Bandwidth Supported on WIC 2AS card on 1841 router, as per techical specifications its supports a maximum of 128 Kps.
Or is it dependent on the back plane speed of the rotuer????
Ranjit Shinde
spremkumar
Level 9
Level 9
Hi Ranjit
As far as i know i dont think anything to do with the backplane of the router as such, its all to do with the Card capability to support the speed.
For higher speed you have various other options and this is designed for 64K/128K line speed.
regs
HI,
Thanks for your reply, please check the attached screenshot the link is terminated on WIC 2 AS card and and still its bandwidth is reaching 1Mb, please find the screeshot for reference.
With Regards,
Ranjit
Dear All,
Also check thos out, latest snapshop.
Ranjit
