MCasting blocked from VLAN to ETH 3Com NBX
networksavvy
I have a new Cisco 871 with this config:
ip subnet-zero
ip cef
no ip domain lookup
ip domain name yourdomain.com
ip multicast-routing
no ip igmp snooping
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 10.1.3.250 255.255.0.0
ip igmp version 3
duplex auto
speed auto
interface Vlan1
ip address 10.2.3.1 255.255.255.0
ip igmp static-group *
ip igmp version 3
router rip
version 2
network 10.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.3.5 permanent
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no cdp run
I am trying to get a POE switch (plugged into F0) and phone (plugged into POE switch) to talk back over the F4 port to our NBX Phone system. F0 is a member of VLAN1.
I get power on the phone, and with my PC plugged into the phone tether port, I get an IP and can ping, etc. The only thing not working is the phone picking up a registration from multicasting from our NBX.
Thing is -- I know its something being blocked on this new 871 VLAN/Multi/Broad/Unicasting because if I bypass it the phone works fine.
Since this is an smaller 871 - PIM, Sparse, Dense, etc. all are not available to me.
I was hoping to get this router in our remote office this evening but I cannot for the life of me figure out how to get the router to just pass on all multicasting.
Can anyone make any recommendations?
Thanks!
Edison Ortiz
F4 and F0 are on different subnets. In order to transport multicast packets between subnets, it must be routed.
You've already stated this router does not support PIM so you have 2 choices.
1) Have only one Vlan
2) Get a device that support multicast routing and enable it on both Vlans.
HTH,
__
Edison.
rskoog
What version of IOS are you running?
And when you say the phone doesn't work, do you mean it can't find the PBX or it doesn't have a dial tone? (Phone appears to register, shows time and extension, but doesn't work)
