ME3400E NAT support?
AquaGoat
I was recommended ME3400EG-2CS-A with METROIPACCESS to use as a router for a project. It appears these switches do not support NAT? Is this correct?
I just want to make sure there is definitely no NAT support on these devices before I arrange to have them replaced with something else.
Thank you
HOSTNAME(config-if)#ip nat inside
% Invalid input detected at '^' marker.
HOSTNAME(config-if)#int gig 0/2
HOSTNAME(config-if)#ip nat ?
% Unrecognized command
HOSTNAME(config-if)#do sh vers
Cisco IOS Software, ME340x Software (ME340x-METROIPACCESSK9-M), Version 12.2(60)EZ13, RELEASE SOFTWARE (fc2)
pchiava
I have a few of these that I was using for it's selective q-n-q feature, but no NAT available on this switch platform and same goes for the next newer ASR-920.
I'm afraid you will need to move the NATing to a router.
Hope this helps you out, thanks.
-Piero
I have searched this information in the feature navigator, and No, this device does not support that feature, you can use the tool for your reference:  http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Please do not forget to rate useful post.
Best Regards,
