02-23-2006 04:22 AM - edited 03-03-2019 11:50 AM
Hi ,
please anyone tell me the meanings of these alrams which are coming in my MGX 8850
M8850_SF.10.MPSM155[FR].a > dsplnalmcnt 1.1
Line Number: 1.1
Elapsed Time(in sec): 397
Num of LOS : 0
Num of OOF : 0
Num of RAI : 0
Near End Far End
CurrentCCVs : 0 CurrentCCVs : 0 <--------- This
CurrentCESs : 0 CurrentCESs : 0 <--------- This
CurrentCSESs : 0 CurrentCSESs : 0 <-------- This
CurrentUASs : 6 CurrentUASs : 6 <-------- This
CurrentLCV : 0 <------------
CurrentLES : 0 <----------
CurrentLSES : 0
CurrentPCV : 0
CurrentPES : 0
CurrentPSES : 0
Current24HrLCV : 0
Current24HrLES : 0
Current24HrLSES: 0
Current24HrPCV : 0
Current24HrPES : 0
and due to which error do we get this alarms
regards
02-25-2006 12:54 AM
Num of LOS : 0
Number of "Loss Of Signals"
Num of OOF : 0
Number of "Out Of Frame" conditions
Num of RAI : 0
Number of "Remote Alarm Indicator" occurences
Near End Far End
Current "NE/FE alarm conditions"
Current "Channel Code Violations"
Current "Channel Errored Seconds"
Current "Channel Severely Errorred Seconds"
Current "UnAvailable Seconds"
Current "Line Code Violations"
Current "Line Errored Seconds"
CurrentLSES : 0
Current "Line Serverely Errored Seconds"
CurrentPCV : 0
Current "Path Code Violations"
CurrentPES : 0
Current "Path Errored Seconds"
CurrentPSES : 0
Current "Path Severely Errored Seconds"
Current24HrLCV : 0
"Last 24 hour Line Code Violations"
Current24HrLES : 0
"Last 24 hours Line Errored Seconds"
Current24HrLSES: 0
"Last 24 hours Line Severely Errored Seconds"
Current24HrPCV : 0
"Last 24 hours Path Code Violations"
Current24HrPES : 0
"Last 24 hours Path Errored Seconds"
The generally have to do with your line format - STM1 and the multiplexer stuff behind. You can define the error/alarm counters and conditions with xcnfalmcnt and you find an description at
Hope this helps! Please rate all posts.
Regards, Martin
02-26-2006 07:22 AM
To elaborate further on the errors:
Num of LOS : 0
Number of "Loss Of Signals" These are the loss of input signal to your interface. Caused by many reasons(no cable)
Num of OOF : 0
Number of "Out Of Frame" conditions This is the loss of framing to your interface. This is where you have a signal but no framing. Can be caused by the carrier not configured correctly.
Num of RAI : 0
Number of "Remote Alarm Indicator" occurences . This is an indication that the remote end is seeing an alarm from you. Maybe they lost signal from you or your xmit is bad. They will send this alarm to you.
Near End Far End
Current "NE/FE alarm conditions" This is another alarm that is similar to the previous.
Current "Channel Code Violations" This is in reference to the line code (B8ZS, AMI). This can be caused by a mismatch of line coding from you to the carrier.
Current "Channel Errored Seconds" This is a count of errored seconds from a time reference (counters cleared). You need to look at this error along with the following ones to determine how bad your problem is.
Current "Channel Severely Errorred Seconds" This is a counter on severly errored seconds. The previous error was just errored seconds, this counter shows you long and continuous errors on the line. Again, you can determine and figure out you problem by looking at these errors.
Current "UnAvailable Seconds" This shows you the current unavailable seconds. This means you have a loss of signel now on the line.
Current "Line Code Violations" Shows current line code violations. This is real time not like the one above which showed you the errors that happened.
Current "Line Errored Seconds" This is the line errored seconds where the counter shows you the framing errors of the line. The error above is for clocking this is for framing.
CurrentLSES : 0
Current "Line Serverely Errored Seconds" The same for framing to show you severly errored seconds on the line.
CurrentPCV : 0
Current "Path Code Violations" This shows you the total path (point a to z) and if you had any path code violations.
CurrentPES : 0
Current "Path Errored Seconds" Same for the path to show you path errored seconds.
CurrentPSES : 0
Current "Path Severely Errored Seconds" Sam as above...
Current24HrLCV : 0 These remaining errors are accumulations throughout the past 24 hours...
Current24HrLES : 0
Current24HrLSES: 0
Current24HrPCV : 0
Current24HrPES : 0
Hope I clarified these errors for you.....
