Accessing Servers behind NAT
anka_ozcan
hi;
I have a FTP server behind NAT enabled Cisco router.I want to access FTP server from outside, with configuration below, when I tried to connect FTP server, from netstat command output on FTP server I see there is a connection to FTP port but wait in LISTENNING state. What is the problem?
interface FastEthernet0/0
ip nat inside
speed auto
interface Serial0/0
ip address <....public ip....>
ip nat outside
no fair-queue
<...rest...>
interface Serial0/1
no ip address
shutdown
ip nat inside source static tcp 192.168.1.2 20 interface Serial0/0 20
ip nat inside source static tcp 192.168.1.2 21 interface Serial0/0 21
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
no ip http server
5 Replies 5
pkhatri
Level 11
Level 11
The fact that you can see the FTP port in a LISTENING state simply means that the FTP server is running okay.
I presume you are FTP'ing to your router's WAN IP address, right ?
Can you do a 'debug ip nat detailed' on your router to see whether the router is performing NAT or not ?
Paresh.
you might want to try and add the keyword 'extendable' to your NAT statements:
ip nat inside source static tcp 192.168.1.2 20 interface Serial0/0 20 extendable
ip nat inside source static tcp 192.168.1.2 21 interface Serial0/0 21 extendable
GP
OK. but what about if we use route-map ?
for example for configuration below:
ip nat inside source route-map Dialer0 interface Dialer0 overload
ip nat inside source route-map Dialer1 interface Dialer1 overload
access-list 97 permit 192.168.1.0 0.0.0.255
access-list 98 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map Dialer0 permit 10
match ip address 97
match interface Dialer0
route-map Dialer1 permit 10
match ip address 98
match interface Dialer1
<..rest of the config...>
balajitvk
Level 4
Level 4
There is a document that describes different modes of ftp and also the problems faced by customer behind one side of nat to connect to the server.
http://www.openbsd.org/faq/pf/ftp.html
i hope this will help u!
ekiriakos
Use the extendable keyword as suggested by GP eralier. You can still overload on the external i/f
Rgds
E.
