Measure capacity of Point to Point Lease line, Given by ISP
Kuldeep singh
Hi Experts,
Suppose i have 5 mbps Point to point Lease line (fibre or copper) which connects two sites A and B, distance around 5 Kms.
Here i am talking about only Point to point lease line which have no internet, plz do not consider Internet Lease line.
I can easily check bandwidth of Internet Lease line but i do not know any method to test point to point LL Connectivity.
I Read out many cisco support forms but there is no any exact solution.
There are everyone suggesting only Tools and  i Know about every monitoring Tools like as
Whatsup Gold, Cacti, Ipserf,Netflow, PRTG, MRTG, Solarwind, Opmanager....
I am confuse because these above tools gives only information of Bandwidth usage report of Date-wise,Hour-wise, etc.
It does not matter for me that what is Bandwidth usage of Per day, per hour, IN and OUT traffic and whatever.
Only Point to Point lease line should be 5 Mbps....... That's it
So please solve my given below Questions =>
1. Suggest me exact tool or Method, if you have any screenshot or documentation plz share with me ?
2. How to measure P2P leased line speed/Bandwidth using ping output ?
3. Suggest me freeware tools to checkout user-wise/ip-wise status of upload and download ? i have not yet found
4. in my case, can i say "Speed" at place of "Bandwidth"....Yes or No ?
If you are fully confident and you have checked practically then revert me otherwise Plz ignore...........
Hello Kuldeep,
What i do normally, is to setup an FTP server with a file of 100 MB size and try to download it from the other end
and see how long it took to download the file.
100 MB flle take 8 seconds over 100 mbps line..
so your file should get downloaded in 160 seconds
Please rate all the helpful posts
Harish.
7 Replies 7
Hello Kuldeep,
Harish.
thats an example dear..
100 MB file 100mb/s line takes 8 second to download technically
in your case you have 5 mb/s speed so it takes 160 second to download the same file
hope its clear now
Harish,
Hi Harish,
                which FTP server i needed.....
                can u plz give me reply of remaining questions 2, 3, 4
you can use normal windows server or 3cdaemon to setup and FTP
regarding the other questions
Hello Kuldeep
2. How to measure P2P leased line speed/Bandwidth using ping output ? - I dont think we can measure using PING
3. Suggest me freeware tools to checkout user-wise/ip-wise status of upload and download ? i have not yet found- Karsten has posted one which he has used. should be good..
4. in my case, can i say "Speed" at place of "Bandwidth"....i think both are same ?
read this by scott
https://learningnetwork.cisco.com/thread/7633
I usually use the good old Iperf for this kind of tests: http://sourceforge.net/projects/iperf/
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Aren't they all answerd? What is still unclear?
vmiller
Level 7
Level 7
its not speed. It is capacity (bits per time interval)
http://www.google.com/search?hl=en&newwindow=1&client=firefox-a&hs=4Q0&rls=org.mozilla:en-US:official&q=ip+traffic+generator+freeware&revid=124548436&sa=X&ei=NeBlUKHOIKmOiALRsYCACw&ved=0CH8Q1QIoAA&biw=1912&bih=936
you will need to take a look at tcp settings on any workstation involved. Past experience indicates that thats usually where things don't work right.
