Media Type Combination interfaces
Yossarian
Hi!
Im trying to discover which interfaces some remote routers are using on combination interfaces (This one - 4431 router)
This one I presume its using an LX SFP - not DOM capable!
#sh int g0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
Full Duplex, 1000Mbps, link type is auto, media type is LX
I presume this one is using GE T SFP when it could use the Rj45 port as its a combination Interface?
sh int g0/0/2
GigabitEthernet0/0/2 is up, line protocol is up
Full Duplex, 1000Mbps, link type is auto, media type is T
And this one again a combination interface using the RJ45 port
#sh int g0/1/0
GigabitEthernet0/1/0 is up, line protocol is up
Hardware is NIM-2GE-CU-SFP,
Full Duplex, 1000Mbps, media type is RJ45
Im not sure im media type T or media type RJ45 are the same thing??
thanks
Mark Malone
GLCT or GLTE is just the copper ethernet sfp that goes into a fiber capable port to allow copper cable connection, the rj45 is copper ethernet connection too
the G0/0/2 is dual can be copper or fiber depending , g0/0/1 is copper only and your g0/1/0 should be able for copper or sfp , there should be 2copper and 2 sfps available in that extra card
im not sure im media type T or media type RJ45 are the same thing??
correct
If I am correct:
Media Type T means that Copper SPF is connected to Port.
Media Type RJ45 means there is no SPF connected to Port and it's a simple Ethernet port.
I have lab router running
Full Duplex, 1Gbps, media type is T  - CAT6 ethernet and not fiber.
