mem swap back to original now it is not working
chr6is000
my first router had issues saying the the requirment exceed the available memmory and kept cycling through rommon. so i did a tftpdnld to delete all memmory and reload the flash. nothing happend so i thought it might be the memmory module. i took the memmory from another router exactly the same and swapped everything and it did the same thing still, so i thought it could be the motherboard.
anyways, i then swapped the memmory back to the original router that was working perfectly fine and noe it is cycling through and saying this>>>
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 32768 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0xf14944
Error : memory requirements exceed available memory
Memory required     : 0x02711C48
*** System received a Software forced crash ***
signal= 0x17, code= 0x4, context= 0x800805d0
PC = 0x0, Vector = 0x0, SP = 0x0
rommon 1 > dir flash:
         File size           Checksum   File name
  15813348 bytes (0xf14ae4)   0xe6d6    c2600-entbase-mz.124-25d.bin
       887 bytes (0x377)      0x125d    stary
any thoughts??????????? i just lost my home lab that i was studying with to get my ccna
chr6is000
sorry everyone and thanks i found the problem. the first router  having the problem was the module must have popped out the first time(no  clue how). then when i swapped i actually did the same thing and did  not push hard enough to pop it in all the way.
i realized this when it loaded and i saw it said only 32 mb of main mem and i knew i had 64mb
so i figured out that the module was not in all the way, i popped it in it then said 64 mb and went to set-up mode
thanks,
i wont bother you anymore
