Memory fault on cisco 7246.
stephtchoko
Level 3
Level 3
We have removed a software from flash memory, and replace it by a new software.And we have format bootflash memory and replace it by a new sofware.
The UBR7246 can't load memory normally, we have some error while booting:
System Bootstrap, Version 11.1(13)CA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1997 by cisco Systems, Inc.
C7200 processor with 131072 Kbytes of main memory
Self decompressing the image : #################################################
############################################################################ [OK
00:00:03: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
%SYS-4-CONFIG_NEWER: Configuration from version 12.2 may not be
correctly understood
00:01:34: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot
loader.
Explanation At least one informational or error message has been printed by the boot loader.
################################################ [OK]
Restricted Rights Legend
Any suggest will be appreciate.
Best regards.
pradeepde
Level 5
Level 5
See the following link for a similiar issue, check the workaround given :
http://www.cisco.com/en/US/products/hw/routers/ps359/products_field_notice09186a0080094c99.shtml
