Memory utilzation thresholds
santoshdpawar
Hi Guys,
Is there any standard threshold for Cisco 1800 router memory utilization after which we should really look after for upgradation ?
I have observed 70% constant utilization for almost 6 months but want to know if any standard cisco white paper available for thresholds.
Santosh
Hello Santosh,
You have  currently 67 % of memory being used. The one which you are seeing is allocated memory by BGP process over a period of time and if you see multiple outputs you can see that, allocated and freed memory counter are getting increased.
It allocates and free the memory after sometime. The  holding memory is the actual memory being used by each process .
Hope it helps
Harish.
Hello Santosh,
I dont think there is some defind threshold for 1800. But if you are  not facing any issue to the current traffic , you are good to go till 80% I believe. If you have a plan for IOS upgrade or any additional feature in near future, then yes you can go for an upgradation
hope this helps
Harish.
Please rate all helpful posts!
Thanks Harish for the reply. I have seen BGP processes (PID=257) showing almost 2GB. I guess there is something wrong ?
sh processes memory sorted
Processor Pool Total:   56005568 Used:   37035216 Free:   18970352
      I/O Pool Total:   12582912 Used:    6470464 Free:    6112448
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  113047192   75098056   33171188          0          0 *Init*
   0   0          0          0    1690032          0          0 *MallocLite*
   0   0  115584936  100046448    1402268    1624852          0 *Dead*
257   0 2345376292 1743803308    1354248          0          0 BGP Router >>>>>>>>>>>>>
I have IOS : c180x-advipservicesk9-mz.124-24.T2
Santosh
Hello Santosh,
Hope it helps
Harish.
Thanks Harish
