Metro Ethernet VLANs
istrimback82
Hello!
I've been digging through metroe best practices, but all I can find is ISP points of views on creating a metroe WAN rather than from an internal business standpoint. My company is getting a metroe circuit in two weeks so I'm labbing up a WAN in GNS3 and my configurations aren't working. The MetroE will be a point-to-point connection. The main site will have the MetE circuit going into a Cisco 3750 and the remote site has a 3750 as well. I am going to use 802.1q trunks for the metroe traffic. My problem is I can ping the gateway for the vlan 3 at the remote site (192.168.201.1) from corporate, but I can't ping the PCs. This could be a GNS3 limitation or a screwed up Metro VLAN design all together. Any input here would be much appreciated. Here is the configuration for the Cisco 3750 at corporate:
*output omitted*
vlan 200
name MetE-Point-to-Point
interface fa0/1
description Trunk2MetE
switchport mode trunk
interface vlan 200
ip address 10.10.200.1 255.255.255.252
ip route 192.168.201.0 255.255.255.0 10.10.200.2
Cisco 3750 Remote Site:
*output omitted*
vlan 3
name Comp-LAN
vlan 200
interface fa0/1
interface fa0/2-24
switchport access vlan 3
interface vlan 3
ip address 192.168.201.1 255.255.255.0
interface vlan 200
ip default-gateway 10.10.200.2
ip route 0.0.0.0 0.0.0.0 10.10.200.1
istrimback82
Correction on the remote site:
vlan 200's ip is 10.10.200.2 not 10.10.200.1 like the config shows.
