Bookmark
Subscribe
3035
Cisco 2811 not booting
pmarques
A client has 2x2811 acting as Voice Gateway and backup Voice Gateway and both, after some undisclosed circumstances, are not booting.
After some troubleshooting a faulty memory DIMM was detected on the primary Voice Gateway. Still, DIMM replaced, it continued failing to boot. Tried the other router and the symptom was the same:
Cabvg010
Expected a checksum of 0xC117781E
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x80026fa0
PC = 0x8000f0d4, Cause = 0x20, Status Reg = 0x3040a803
c2811 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x3edeb34
Error : compressed image checksum is incorrect 0x8543774D
Error : compressed image checksum is incorrect 0x256A274E
System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Initializing memory for ECC
Cabvg000
Bad RAM at location 0xA0000004: wrote 0xA0000004, read 0x00000004
Cabvg010
monitor: command "dir" not found
rommon 6 > dir flash:
Directory of flash:
24563    65924348  -rw-     c2800nm-advipservicesk9-mz.151-4.M6.bin
9400    2900      -rw-     cpconfig-2811.cfg
9401    2324992   -rw-     cpexpress.tar
9969    1038      -rw-     home.shtml
9970    115712    -rw-     home.tar
9999    527849    -rw-     128MB.sdf
10128    1697952   -rw-     securedesktop-ios-3.1.1.45-k9.pkg
10543    415956    -rw-     sslclient-win-1.1.4.176.pkg
10645    57005524  -rw-     c2800nm-advipservicesk9-mz.124-22.YB5.bin
rommon 7 >
I tried changing the boot sequence, uploading a new version via tftpdnld,15.1(4)M8 (verifying that the checksum on the file was the same as on Cisco CCO), formatting the flash. All failed.
As of now, I have no more solutions to turn on to.
Has anyone faced a similar problem able to provide some help?
TIA,
Pedro Miguel Marques
Leo Laohoo
Read this:  Field Notice: FN - 63405 - CISCO18XX & CISCO28XX Might Fail to Boot After a Power Cycle - Fix on Failure
I strongly recommend you get the chassis replaced.  If you don't have a valid maintenance contract, don't despair, you still got some home.  Contact your nearest Cisco AM/SE and show them the document above.  Initially, they might feign ignorance but they are to honor all complaints.
Hi Leo,
Thanks for the link. I'll forward it to the client. It might be helpful.
regards,
If the DIMM was replaced, and the device still failed to boot, it wouldn't be the field notice mentioned... unless the memory installed was bad.
Also, the field notice has nothing to do with whether or not your parts are covered by a contract or not. Some field notices are of that nature (a recall) but this one is not.
And someone gave me a "3"????  cheeky
